trigger assembly
woodchuck
Hi all.I've got a 84 mecr 150 black max,when I put hammer down,it acts like it is loaded up on gas, it spuders a little while,then take off and runs good.Is this in the carbs or may be the trigger assembly? Thanks in advance.
Laddies
Banned
Re: trigger assembly
Ussally a bad trigger don't go away, is probably a carb flooding
Chris1956
Also, if the fuel pump diaphram leaks, raw fuel will flood into the crankcase. This will load up some of the cylinders.
