ugalboogala
- Sep 24, 2003
- 11
Iv just done a trigger resistance test on my engine,the one where you check between the vilot an the white an the brown wires,yellow sleve an without..all right?now my question is while holding the meter on any of the two ,mainly the brn w/o yellow and the wht w yellow,i can hold the harness under the fly wheel an slightly shake them an watch the meter,"keep in mind that the meter wires are clamped securly to the trigger wires"i noticed that the readings fall below the req.specs. is this supposed to happen?thanks in adv!
