Trigger test specs.
jerryjerry05
I need the test spec for a 1988 125hp.
​I have the stator spec but the trigger color code seems to be different on the trigger.
It has multi colored trigger leads.
I tried CDI but didn't have any luck?
Outboard Ignition too??
​Thanks,Jerry
Nordin
Jerry send me a PM.
I have the factory service manual 1988 thru 1991 A models (OB4642).
Wright the spec. values you want and I try to give you the answers and I will also translate and correspond the colours for the wires.
There are one colour or multiple (three colours) at the trigger.
jerryjerry05
Thanks for the offer.
​I got a color chart and figured out the tests.
Problem might be??
​It OHMS right about 38-40 on all 4 cyl
The second is voltage.
#1 is 7 #2 is 5 #3 is 6 #4 is 25V DVA .
​I contacted CDI and they haven't replied to my question of?? is 25V too much? Would that make the trigger bad??
​I just rebuilt this 88/125 it needed 2 lower pistons.
Compression is about 160 on all 4.
​I don't think I did anything wrong during assy..
​It starts and backfires.
​But stops the backfiring when #4 is unhooked???
It was supposed to run before he brought it to me??
​I rebuild. try to start?? NO spark??
​Tested stator. BAD!!
Continued to run crappy and backfiring.
Found #4 coil bad??
NEVER had this much trouble on ANY motor.
jerryjerry05
Thanks Nordin.
​According to the good people at CDI.
They say the pack is probably bad??
No mention about the 25v on trigger lead #4?????????
​Going to replace it today and hope it works.
My customer want to fish in a tournament this weekend.
