Out on the water and all of a sudden the boat starts running a bit rough especially when i move the trim. when i hit the trim switch the voltage reading goes way down and the boat skips like it shut off, even burped through the carb once. seems like its an electrical issue with maybe a bad battery or more likely alternator. can it be that the trim use is causing a drop in voltage that affects the engine running due to decrease in voltage? just prior to this i hit a sand bar pretty hard with outboard, but it didnt start happening right away. any thoughts
