Re: Trim and Tilt issues
First check the manual release valve. Rest motor on locks and check oil resevoir level. I will show you how to trouble shoot the electrical system below, with help from the nifty chart ezeke supplied, it will help in this. It took me a long time to type, so i hope it helps, lol.
1. Make sure battery is FULLY charged.
2. With a voltmeter, connect red lead to point E1 in junction box and meter black lead to point G. Meter should indicate battery voltage.
3. If no voltage is indicated, move meter red lead to poiint E2 on solenoid. If battery voltage is indicated check FUSE in junction box. If no voltage, check red and black leads to battery for poor connection or open circuit. Polish them up, no corrosion, dirt, rust, etc...
DOWN CIRCUIT
1. Move red meter lead to point E3 in junction box, push trim switch in the down position. Battery voltage should be indicated. If trim motor does not run, test motor.
2. If no voltage is indicated at point E3, move meter red lead to trim switch at point E4 and meter black lead to point G1. Push trim switch in down position. If meter indicates battery voltage, lead is open between point E3 and E4.
3. If no voltage at point E4, move meter red lead to point E5 in trim switch. If battery voltage is indicated, trim switch may be defective.
4. If no voltage is indicated at point E5, check continuity of ground lead from trim gauge G1 to junction box point G. If ground lead is good, move meter red lead to junction box at point E1 and meter black lead to point G on junction box. If battery voltage is indicated, lead is open between E1 and E5.
UP CIRCUIT
1. Connect voltmeter red lead to junction box at point E6 and meter black lead to ground at point G. Push trim switch up. Battery voltage should be indicated. If trim motor does not run, test motor.
2. If no voltage is indicated at point E6, move meter red lead to point E7 on solenoid. Push trim switch in up position. If voltage is indicated, blue lead is open between E6 and E7.
3. If no voltage is indicated at E7, move meter red lead to point E8. Push trim switch in up position. Battery voltage should be indicated. If trim motor does not run, connect meter red lead to point E2 on solenoid. If battery voltage id indicated, solenoid is DEFECTIVE and must be replaced.
4. If no voltage is indicated at point E8 on solenoid, move meter red lead to point E9 and meter black lead to ground at point G1 on trim gauge. Push trim switch in up position. Battery voltage should be indicated. If battery voltage is indicated, lead is open between E8 and E9.
5. If no voltage is indicated at E9, move meter red lead to point E5 on trim switch. If voltage is indicated, switch is defective and must be replaced.
6. If no voltage is indicated at E5, check continuity of ground lead between trim gauge G1 to G in junction box for open circuit.
7. If ground lead is good and no voltage at E5, move meter red lead to E1 in junction box. If voltage is indicated, lead is open between E5 and E1.
