jerry from michigan
- Jun 30, 2003
- 1
Hi all, hope someone can help! I took on water (about to the mid calf at the back of the boat) My engine never quit working. However after this my tilt and trim don't work. I can here a clicking noise when i try to operate the tilt or trim. I replaced the four celenoids and still have the same click. Both moters run when bypassed. I have think i hava a 1986, 2.5 litre OMC(gm) engine (boat is 1986)and an OMC stern drive with the rubber boot around it, in a 1986 starcraft. The model number is 252sthrcra and model J315442, it says on the top of the engine 2.5 liter. Hope these corrections make it easier. I have looked for fuses or other connection. My trim switch is in the throttle handle, tilt is on the dash. The trim is in the front of the engine tilt in the rear. Thank you for any help. Jerry
