Re: trim and tilt question
Can I wire in a switch to the back of the motor? My trim only works from the front controls. If so, does anyone know which wires I need to use. I have a 1994 force 120hp. Thank you
if your engine came with trim relays or trim solenoids then you can wire in as many switches as you want.
Every switch is exactly the same as the console switch. It will have one 12VDC inputs, and two outputs. The switch should be SPDT momentary with center off. For exposed locations get a sealed switch with mounting gasket. When the switch is pulled up the blue/wht wire should become active. When the switch is operated down the green/wht becomes active.
All thee wires to the switch are control signals and should be 18-22awg. The input needs to be protected with a small fuse. The outputs should be run back to engine and spliced into existing control wires. 3m squeeze on wire taps work well. Get a high quality connector and seal it when finished. If you have a lot of switches then they may use a common feeder.
If you have a 1987 or earlier 3w trim system then you will need to install relays before you can add a switch. You use a standard 2w trim relay harness with four blade N/O relays. When your motor wears out you can replace with either 2w or 3w. Just use the proper relay with the proper motor.
