Trim and Tilt
GA_Boater
Welcome aboard,Rafe.
It says it's good for up to a 150 lb. motor. Any idea how much your Force weighs?
Rafe
No idea, I use my rig regularly so I don't really want to take it off and unhook everything just to weigh it. If I have to of course I will but was hoping someone might know.
jerryjerry05
Your 35 is under 150#
Contact the maker. They'll probably have a list of motors that fit?/
Look around before you buy I found a few cheaper than $567
Search this site, it might be found here??
You might be able to get the original.
Find a Force/ Chrysler up to 50hp.
They all used basically the same t/t and it could swap to your motor.
Maybe even a running 50 to give you a little more GO!!
jerryjerry05
Yup that would swap.
Since it's been "laying around" check the electric motor for oil intrusion.
Since it's been laying around the pump might not be any good?
Get a guarantee.
The pump part can be purchased fairly cheap if it turns out it's bad.
Also the 2 wires shown. The blue is up and the green is down.
They should have relay's and switches for the motor.
Ask if they are available?
Then offer 200 when they say they don't have them.
I think I have a set you can have for shipping $
