Trim Cylinder Hose Connector(s)
g_speran
Hello ALCON,
In an attempt to remove the trim cylinder hose from the trim cylinder, I was successfully able to strip the top part of the connector that the wrench fits on :facepalm: . With that being said, Can someone tell me what type of connector it is so I can replace it? I am not looking to replace the entire hose as there is nothing wrong with it and the hose costs $41.33 (http://www.mercruiserparts.com/Show...=220&bdesc=TRIM+CYLINDERS+AND+HYDRAULIC+HOSES) were the connector should be $5.00 or less. I have the connector flaring tool (http://www.autozone.com/autozone/accessories/Tools-Garage-and-Equipment/Flaring-Tool/_/N-2658) so putting a new connector on and reflaring it will not be an issue.
TIA
Gary
Re: Trim Cylinder Hose Connector(s)
Hello ALCON,
View attachment 160087 View attachment 160088
TIA
Gary
Ayuh,... It's the same size, 'n thread as standard automotive brake lines, but not SSteel....
I'd just buy the Right line, 'n be done with it...
g_speran
just out of curiosity, why not Stainless Steel? Mine does not have any copper look to it. So is it regular steel then?
Just curious.
TIA,
Gary
g_speran
Well…after much reluctance, I broke down and had to buy the entire thing as Bond-O mentioned. The double flaring tool does not have enough clearance on the tube to create a new double flare once the flare has been cut off.
The positive is, is that I did not have to pay the $41.33 as mentioned. I found it at http://www.shop.tungstenmarine.com/...ercruiser-NEW-DESIGN-TM2103.htm?categoryId=-1 for $18.95 + $4.00 S/H.
TIA,
Gary
