UncleWillie
- Oct 18, 2011
- 3,995
I took the out-drive off the boat a month ago for the winter.
The Battery was removed and the boat was covered for the duration.
A week ago I looked at it and one Trim cylinder had extended about 2 inches, all on it's own.
So I hooked the battery back up and hit the down button and heard the trim pump straining in bypass mode against the down stops.
The Port side Cylinder would not retract and was still extended. ???
So next I hit the up button and both Cylinders extended, in formation, Port side leading.
Once the Port Cylinder reached Max extension the Starboard side continued until it also reached Max extension and the trim pump went into bypass, again as expected.
Pressing the down trim caused both cylinders to retract equally to the fully retracted position which is what I wanted in the first place.
Now, it is cold and snowy and Ohio so there is not much boating going on, and the Cylinder has stayed in for the past week, so I really have no problem to solve.
So just out of boredom and curiosity;
Would anybody like to suggest a reason as to;
1. Why the cylinder extended in the first place.
and ...
2. Why the cylinder would not retract initially without being fully extended first?
(It is going to be a long Winter!)
and ...
