I have read a number of trim question on here but can't find exactly the problem I am experiencing.
I have a 120 HP Force Year. Serial number is OE006543 so year is 1992 I think.
The motor trims up as soon as I press the tilt/trim switch but will sometimes not trim back down. When I hit the switch to trim down there is often a delay of 5 seconds or so before it suddenly starts to go down. No sound or anything, just nothing and then it will eventually start to trim down. This is an intermitent problem. Once the motor does start to trim downI can make it stop and start trimming again quickly.
By reading the forms I assume this could be a relay problem? If I need to replace them, can someone give me the part number. I think it might be 803632T but not sure as I can't tell if the diagram for the part is my exact model.
PS, this is my 20th year with this boat and motor and it still runs great (had one rebuild after a broken ring). You will see form the pictures it still looks mint!
Regards, Nick
Regards, Nick
