IES99
- Jun 3, 2008
- 271
I have two problems with the tilt/trim on my 1988 Alpha One: 1. Water in hydraulic fluid (its a milk shake) and 2. Very slow up with both tilt and trailer. From reading here on the helpful Forum I have plans to: 1. Change the seals at the ends of the cylinders and 2. Drain, flush, refill and bleed the system. So here are the questions:
1. When I disconnect the cylinders from the stern drive, should it be in the full down or up position?
2. When I want to start draining the system, which hydraulic hose should I disconnect first?
3. Should I then run the pump several times to completely drain? I understand that I will need to add fluid so that the pump is not run dry, is that right?
4. I understand that getting the sealing nut off the rear of the cylinder with the pin type spanner can be tough. Any suggestions on how to speed this up?
5. Once I have it all back together, I start putting fluid back into the reservoir and keep pumping up and down while continuing to add hydraulic fluid to the reservoir to bleed the system. Is that correct?
Thanks in advance and appreciate any thoughts on each of these steps.
Ed
Ed
