Re: Trim gauage
Check power AND ground are good and solid at the gauge, check the connectors to the sender at the back of the engine (which, btw is what???), check continuity of the sender wire to the gauge. Also check the harness plug is good (remove and splay the pins SLIGHTLY)...
If all that checks out, the sender's gone south....
Chris........
