Re: Trim gauge not working still......
I had this problem too and bought new senders, but decided I didnt want to take everything off. When I looked at the units, I saw that a wire had broken off at the sender. The wires right at the sender seem to corrode and break so check there. I unscrewed the sender and there is a screw where the wire goes in, take that off and you should have a stub of a wire left. I took a butt connector, removed the insulation and crimped the wire back together. I then soldered it, put the sender back together and coated it with liquid wire tape. The guage is working again and hopefully it will last until the end of teh season when I will replace the bellows and do everything at once.
