trim gauge not working
jshop
88 johnson spl on sending unite wire missing and dont no where it should connect to
Chris1956
Re: trim gauge not working
The trim senders are inside the transom bracket. Tilt up the motor and look for a black plastic lever inside the transom bracket, that would contact the motor tripleclamp. The sender wire should be ganged with the PTT motor wires and run into the bottom cowl.
