Trim Gauge not working
MARCD
I have a 2003 Larson 190. The trim gauge is not working on land, but it sometimes works when the boat is moving in the water. Do you think the gauge is bad and how do I check it?
Thalasso
How to check sender.
https://youtu.be/uEppsHn8ezg
To check if gauge works (only works) is to jump between the send post and ground on the back of the gauge for a split second. Needle should jump from one side to the other.
