Trim/Gear oil mixup
marc5959
Question for Whoever, what happens when you, stupidly, put a half oz of trim fluid in the gear lube reservoir before you realize you are messing up?
stresspoint
probably nothing , 1/2 an ounce over the big picture is not a lot .
Ayuh,..... It's easy enough to remove the hose from the bottom of the bottle, pull, 'n clean the bottle, then reinstall, 'n refill it with gear lube,.....
Probably a good idea anyways, as sludge forms in the bottom of the bottle over time, 'n needs to be cleaned out occasionally,.....
marc5959
Thanks thats what I think also, it would be easy to pump all the lube in the reservoir out and refill, haven't ran the boat since my blunder but I don't think I'm going to worry about it?
Scott06
Doubt it will make much diff or this lube even get to the outdrive, but I use a turkey baster for things like this- suck the reservoir dry. Every couple years I use it to change out my trim fluid - suck it out and refill, run it up and down, refill etc
