I have a 1998 Stinray 22' cuddy cabin. If the drive is on the full down position the up button will only bring it up slitghtly (probably less than a inch)and then I have to use the trailer up button to bring the drive up and to the full up position. Would it likely be the up/down switch or the limit switch on the drive causing this. There appears to be a red wire cut on the drive motor. Also, the trim guage doesn't work. Any pointers on how I should begin testing to narrow down the problem?
