I just bought a 75 glasstron with a volvo penta AQ130C and a 270 outdrive. The outdrive will not go up or down when you run the trim pump. I can feel the electric pump working. My question is does it have a hydraulic resevour or is it all electric with worm gear. I dont know if it has trim and tilt or just trim. The consol switch says trim/tilt on it. There is a stap that holds the outdrive up when driving and when you release the strap the outdrive goes down by itself. I see on the outdrive bell houing on the inside of the transom that there is a white plug is that a fill plug for something? Also does anyone have a repair manual for this engine? Thanks for your help.
