Hi,<br /><br />my trim motor housing is getting very warm after raising/lowering the motor a couple of times. In addition the red lead (directly from the battery to the unit) was getting VERY hot (almost enough to cause a burn). I noticed the ternimal area was corroded and cleaned the connection area. It does not get as hot now, but still gets pretty warm. The motor housing still gets pretty warm (not rediculously hot). Should there be some heat like this or am I statrting to have a problem of some type? <br />After I clened the terminal area the unit lifted the motor significantly faster.<br /><br />Thanks in advance.
