Trim motor help
Fruitcake
Have a few questions-<br />So I came to the conclusion that I need to replace my trim motor. I've tested everything else and hooked the motor straight to battery, to no avail. Anywho, I need to pull the trim motor out and replace. I'm new to this boat scene and don't understand what needs to happen to get the motor out. Got all but one screw that has no chance of coming out :mad: <br />Thanks<br /><br />1990 18' Ranger Apache 150XP Evinrude
Fruitcake
Re: Trim motor help
Hey, great forum you have here, very helpful!!<br />A+<br /><br />Thanks!
Walker
Re: Trim motor help
That's no way to get help!!<br />But anyway, Tilt your motor all the way up and set the trailoring block. Look at the big, fat, short pin that goes through the shaft to the tilt. Remove the snap ring on one side and drive the pin out. Should be able to now swing the tilt assembly out far enough to get to that last bolt.
