Trim motor issues motor runs than stops
Jasonscott
The boat is a 74 so I think I have the prestolite motor. Whats going on is the motor will run for a little bit than it stops. If the drive is all the way down and i start to go up the motor will run till the drive is about 3/4 of the way up than quits. I stop for a little and it will run again for a little bit, it does this both up and down. I took the motor apart and cleaned it and thought the bi-metal switch didnt look very good. could this be my problem?? How long should i be able to run the trim motor without that particular thermal protector shutting it off? Thanks!
jerryjerry05
Re: Trim motor issues motor runs than stops
What switch do you have? You might need to hit two switches at once.
Post a pic of your switch.J
Jasonscott
its not a problem with the switch. it does this even if i run the motor directly with a jumper wire.
