Re: Trim not working 1998 250 Johnson
Obviously you need a better manual.Try for the factory original .... it's the best.<br /><br />I think your V6 has a trim limit switch that is sticking.If you pull the cover off the motor,and both lower pan covers,you should see it.About dead center,below the carbs,near the tilt tube.<br /><br />DHP
