Trim not working
Sdanglerz760
My kickstand that holds the motor in the up position got jamed had to open use the srew to lift motor to unjam but now the trim motor wont work at all but i can hear the relays click but the trim motor does not make a sound ?
Ayuh,..... Welcome Aboard,...... What motor,..?? what vintage,..??
Ophelia95
If the motor operates, then the problem is a lack of power to the motor (faulty solenoid or relay, bad connections, etc.). Failed solenoids, relays and corrosion (at connections, relay sockets, quick-disconnect plugs, etc.) are some of the most common problems associated with tilt and trim system failure My Card Statement
