Trim on 2008 Four Winns
NHFiore
My trim has been acting up, now stuck in the up position. The power tilt system is SX-A/DPS-A.
I can hear (and feel) that the hydraulic pump is running but the drive won't move up or down, even when trying to help move it. Any ideas if the problem might is low fluid level (before I investigate more)? The manual reads trim drive must be in the down position to check/fill pump reservoir.
Ayuh,.... Welcome Aboard,..... I guess the 1st thing to do, is check the fluid level,.....
NHFiore
Yes, it was lack of fluid. I also found the o-rings probably need replacing - fluid leaks around piston when hitting down stop. Trim gauge not working this year so that's next on the list to fix.
