Trim Panels
tvbjr
Does anyone know how to remove the starboard trim panel on a 1990 245 Vista? :confused:
jsfinn
Re: Trim Panels
Get a bigger hammer than the one you've been using! :)
Chris1956
Re: Trim Panels
Is the trim panel bolted to the gunwale? My SeaRay has SS 1/4-20 screws which pass through the plywood of the trim panel, under the vinyl, so you cannot see them. The ends of the screws go through holes in the gunwales, and have a washer and nut behind the gunwale to hold it on.
