Make sure your older gimbal ring and plate are set up to accept the electric trim/limit sensors. Each has a male 12 pt, shaft that engages the gimbal ring pivot pins, and is clamped with two tapped holes on the sides of the gimbal ring. Most important is the wire harness has a split seal grommet that is clamped into the gimbal plate above the drive shaft bellows. If your out drive doesn't have these features, you're out of luck.
If is does, prepare for a knock down, drag out installing the grommet harness. you'll have to remove the lower unit and bell hsg. to access the clamp bolt, and use a pivoting 7/16 GearWrench ratcheting box end on the bolt. The instructions are in the Sierra replacement kit. You'll need both the trim position and trim limit switches to get a full seal grommet, a helper and the Sierra gimbal pin removal tool.
