Trim Position When Storing I/O
MariahSX20
Another newbie question but, I read somewhere that when storing an sterndrive engine is important to store it in the trimmed DOWN position, is this true and correct? Can you please explain why?
Thank you again guys, I luv this site!
Andy
Don S
Re: Trim Position When Storing I/O
When down, the exhaust and ujoint bellows are in a relaxed position (less stress). In the winter, it keeps the housing from filling with water and cracking when the water freezes.
MariahSX20
Don thank you for your reply. I am in Florida and of course we do not have a problem with freezing and/or cold weather in the winter, but I guess my question was more as when I have the boat sitting on its trailer in the garage. Will it still make a difference if the drive is up or down at such time when the boat isn't used, perhaps for short periods of time (2-4 weeks) at a time during the summer?
Bondo Again
Ayuh,.....
The Longer the bellows are Stressed,.... The Shorter time they'll Last....
The Choice is Your's...
MariahSX20
Ok guys I got the message. I will leave the drive down when storing the boat, it definitely makes sense to do it this way.
I do appreciate the info very much guys! Thanks, Andy
BAYLINER185
Marahia I have also started to store the boat with the drive down.
I did read it in my manual somewhere about storign it down and as Don explaines it is the bes way.
The bellows streach quite a bit when the drive is up and I only have my drive fully up when the boat is going in the water or commign out, then I store it fully down.
It keeps rain water out of the drive and allows the drive to fully drain when I take the bpat out of the water after each use.
I store my cruiser outside so thats the reason there. My new ski boat is in my garage and not only does having the drive down give me the room to put the boat in the garage I otn use the ski boat any more and I want to aleaviate any stress on te belows and trim system so I also keep that drive down.
a70eliminator
My situation is a little different, during the summer my boat sits in the driveway with bow elevated high as possible for drainage, because when I come home from an outing and the carpet ect is soaked and usually some water in bilge plus any rains we get can all drain out better, I have to have the drive up. In the winter it's in my garage drive down.
chiefalen
i too leave my drive all the way down.i have both boats on trailers.one is a outboard and i leave that one down also.the i/o i also have it with the bow all the way up in the driveway.i find i have just enough room so the skeg don't touch the pavement.only reason i can see to leave a outboard up if its left in the water all the time and especially in saltwater.here in nj you'll see all the outboards up at marinas.
JustJason
i lived in orlando for a few years and it definitely got below freezing some nights!! especially points north and low lying areas like ocala.
dvan1901
Drive should be down. Assuming you have a Mercruiser, read the manual and it will tell you the same thing. It put the bellows in a "relaxed" position and reduces the chance it will rip when you raise and lower it later on.
