Trim problems
djc4868
I have a 1969 Slickcraft SS195. My problem is if I push the up or down buttons the outdrive goes up. I’m lost !
alldodge
Assuming it use to work fine and this just started?
If this is the case it's most likely in the control switch, but first, do you have 2 relays of just 1
alldodge
All good but a Solenoid has a coil and some kind of plunger that is moved. Like a starter solenoid that moves to engage gear into flywheel
A relay has a coil that moves a plunger to make electrical contact to pass power to a higher current device
Chris1956
Not all starter solenoids have a plunger that moves a gear to engage the flywheel. Most if not all outboards do not. Their solenoids simply make an electrical connection of two thick cables supplying enough power to spin the starter. The gear engages under centrifugal force.
MerCruisers, specifically SBCs do have a solenoid that uses a magnetic plunger to engage a gear to the flywheel, for starting purposes, not PTT purposes.
Outboard and sterndrive PTT systems use 1 solenoid, 1 solenoids or 2 relays, depending the year. Newer systems tend to use 2 relays. These solenoids or relays make an electrical connection to power the PTT motor.
If your system trims the motor up, regardless of which button you push, you likely have a wiring issue.
QBhoy
You sure it’s not an older arrangement that may mean you are actually pushing the trim up and trailer button (both will move the drive upwards), rather than presuming it’s the up and down button ? Any pics of the arrangement?
djc4868
Found that the ground was bad. Now I have to another problem, it caught on fire. OUCH!! Burned the wiring. Does anyone know where I can get a wiring harness and shifter and cables?
alldodge
Bummer
For one that old might find one on ebay, otherwise no idea
Maybe change to newer type but this would not use the 3 button type
