Trim pump clicks but does not turn.
BigX
Hello, I have a mercruiser trim pump with up and down solenoids. When I hit the trailer button the outdrive will go up until it is fully up. When I go to trim it down the pump clicks, but the motor does not run. <br /><br />Is the clicking sound the switch in the relay flipping positions? Is this a bad solenoid, pump motor, or trim switch? <br /><br />This problem was happening at the end of last season, but the pump would eventually run and then it would not have the problem for the rest of the day. Only after trailering. I want to fix this problem this year though, before i trailer it to the lake, and have to go home early. <br /><br />Any help would be apriciated, especially with how to diagnose the solenoids/switch/pump. <br /><br />Thanks,
JJJ
Re: Trim pump clicks but does not turn.
It is probably the down solenoid. On my boat they are near the trim motor, if yours are then listen if that is where the click is. You can test it with a voltmeter.<br /><br />Jeff
