Trim pump fluid
jetmart
I have a 1999 5.0 L merc with a trim pump. Slightly low on fluid. The dealer told me to use oil or transmission oil. I searched threads here and some have said power steering fluid.
Currently there is a red fluid in he pump reservoir. What would be best to use and least harmful if I mix?
haulnazz15
Re: Trim pump fluid
I believe power steering fluid is pretty much trans fluid. I'd use the trans fluid if it already has the redish tint. I use straight SAE30 in my trim pump.
jetmart
Re: Trim pump fluid
Thanks. I will use tranny fluid. I thought power steering was the same but the can I have of power steering fluid is clear. Is it worth buying a can of tranny if I have clear power steering fluid.
Re: Trim pump fluid
Ayuh,.. pour in whatever ya got,... The pump won't mind...
If you buy ATF, grab Mercon/ Dextron...
jetmart
Re: Trim pump fluid
I went to buy some from the dealer and he told me to use SAE 30
OnTheWaterNow
Re: Trim pump fluid
My dealer carries Mercury quicksilver power trim fluid
OnTheWaterNow
Re: Trim pump fluid
Theese guys here know what they are talking about.If they say it will work and be ok it will.
