holgo123
- Jun 12, 2006
- 89
I have a 1993 OMC Cobra 5.0 L EFI in a Chris Craft Concept 217 BR that I am re-installing. I have the manuals but can't find this info... I disconnected all the lines and did not make note of their locations... The two lines going in to the pump, one hole has "UP" (the right side), the other is blank (the left side), which position do they attach to the hydraulic manifold block on the transom bracket? Also, if you can describe how the lines should be routed. I have them going from the manifold through the passage on the transom bracket to the right of the manifold block, but how do you route all the line? For the life of me, I can't remember and it seems like there is a lot of excess line... I also have to remount the pump to a new transom. I know it was originally on the upper right side of the transom before... Is there any special care I should take to remount the pump on the transom? Thanks!
