haulnazz15
- Mar 9, 2009
- 3,720
I almost have the 76 Mark Twain runabout back together after a transom rebuild, but have a few details to work out before we try starting it up. First of all, we got the wiring back together and re-connected where I *think* everything went. This is on a 351 Ford w/233 outdrive (pre-apha).
First problem: I pushed the trim up, up/out, and in buttons and only the the up, up/out buttons caused the pump to make a sound. It only clicked when I pushed thm, but at least it told me it was getting power. I know the system needs to be refilled with sae 30 oil as most of it drained out during the rebuild. Also, the trim switch wires that come through the transom plate are the same color and have identical plugs, is there anything that could be harmed if I reversed these? The low pressure and high pressure lines are also Identical in this boat, so those could be reversed as well.
Second Problem: When trying to get the outdrive on (my dad and I attempting to manhandle it) we were having a hard time heeping the unit in Forward gear. If I released pressure on the prop after adjusting the shift arm, the unit would go back into neutral. Any thoughts?
If I can manage to get the outdrive on and verify that the engine runs and goes into gear, then I'd like to get the trim working so we can test it in the water.
