Augoose
- Mar 21, 2010
- 1,236
I have a '89 Mercruiser with Alpha 1.
I've been having an issue with intermittent elevation issues with raising the lower unit - intermittent with both trailer switch and toggle switch (limit switch is bypassed so I know that isn't the problem). It always goes down but is often reluctant to go up, so today I replaced the up solenoid.
Here is my issue - the boat was running tip top (except for raising the lower unit) before changing out the solenoid. Once I changed it out, the boat wouldn't start - just a click coming from what sounded like the starter solenoid. After this click, 12 v was completely dead to the ignition, forcing me to disconnect the battery. Once I disconnect and reconnect the battery lead, 12 v was back again until I tried to start - then just a single click and no voltage once again. I took pictures of the wiring setup prior to replacing the solenoid and I'm 100% positive I had everything hooked up right.
Thinking the new solenoid is bad (why that would keep the boat from starting I wasn't sure about), I put the original back in. Tried to start it up - same issue -click and then no power until I disconnected and reconnected the battery.
In total desperation and not knowing what else to do, I pressed on the shift lock release and rode the shifter forward once and back once, then back to neutral. Tried to start the boat - started right up.
I thought that if the shift interrupter switch was being triggered, the engine would turn over but there is just no spark- isn't that correct?
What else could it have been? Is there some sort of safety device that prevents the engine from even turning over? If it were somehow bumped into gear but still with the shifter "looking" like it was in neutral, would that prevent the engine from turning over and somehow tripping 12v? The main breaker on the wiring harness did not trip even once.
Please help me figure this out before the wife sells the boat out from under me!!!!!
Thanks and sorry to be so long winded.
