1988 Marlin open bow, 4.3 L Mercruiser...
So we put the boat in yesterday, get underway from the dock and I lower the drive all the way down. I start cruising away from the dock and can hear some strange noise, like a pump running.
After a brief look around I realized that the trim pump was running. So I go into minor panic mode and start wiggling wires, fiddling with the trim/trailer switches to no avail.
Luckily, I find my buddy on the other side of the lake who's an electrician. In the mean time, I'm a bit more panicked now, and the pump is getting warm so I break off the power wire to the pump by hand.
My buddy starts with the throttle switches and concludes that they're in working order.
He then takes the "cap" off of the bank of solenoid switches and is able to get the drive up and down by touching the appropriate solenoid with the hot wire that I broke off.
So I'm assuming that my "down" solenoid was stuck in on position and is in need of replacement.
Would you guys agree?
Thank you for any input, and additionally, is it a pretty basic swap out? I'm not a mechanic/electrician, but I can do basic repair,etc...
