seveneleven
- Mar 26, 2016
- 2
Re: 165 trim pump valve body R&R?
One more thing, if you do remove the lines do not remove the 90 degree brass fitting that is screwed into the end of the manifold for the DOWN line. It does have a check ball , 2 springs and a small washer between the 2 springs in there. You don't need to remove it to disconnect the line anyway.
Hi everyone!
Unfortunately, the former owner of my boat disassembled this unit, now the ball, and the springs lay separately from the pump. Can anyone advise, what is the correct sequence of installing them into the pump? I think, the ball should go first into the DOWN hole, then one spring, then the washer, then the other spring, and finally the 90 degrees brass fitting is screwed in. Is this correct? Thank you for any assistance.
Warmest regards,
Andrei.
