Trim Question
GraAlaMat77
Can someone tell me the part number for the trim switch that is at the back of the boat near the motor for a 1988 Venture Tournament Edition Bass Boat. I snapped the swith in half and need to order another one.
Texasmark
Re: Trim Question
If you get no answers, there isn't anything magical about a trim switch. <br /><br />There are many switch mfgr's and dealers. All you need is a 20 amp SPDT (single pole, double throw...which is 2 positions on) spring loaded, sealed (or water resistant) switch. <br /><br />You should be able to find one (www is a good place to start) that mounts (looks) just like yours. <br /><br />On the terminals of the switch, (12v) power input is the center and up is one end and down the other. If you install it and the trim works backwards to what you want, reverse the outer two wires.<br /><br />A marine supply house surely would have it.<br /><br />Mark
bamadave
Re: Trim Question
Posting what boat you have doesn't help. What engine do you have and I might be able to steer you in the right direction.
