Trim questions for an alpha one leg
Tmakaro
Ive been using my boat for 6 years now and when trimming down all the way I alway go by hearing the trim motor change in pitch signaling the leg is completely down. Now I am wondering if the trim stop puck is supposed to detect that or is it just for up? I know that when I trim up all the way it does stop automatically and then I have to press the up button harder to trailer it.
Is it working properly?
Also, I have A puck on each side of my leg and each one has wires going to it. I assume one is for the trim guage which I don't have and one is for the trim stop? Which one is which?
tylermcclintock
Re: Trim questions for an alpha one leg
Trim Sender which controls your trim gauge is starboard side. Your limit switch will be port side
Don S
If you look at those "Pucks" as you call them, you will see they have names on them.
The trim limit switch keeps the drive from trimming up more than a set amount. Does nothing for down.
Tmakaro
Ah, thanks. Ya "puck" is my technical term. I'm Canadian, everything looks like a hockey puck. Lol
