trim rams
altitude 411
I just got my trim switch to operate on the throttle control but I have the out drive off for service. Is it okay to run my trim rams to see if the limit switch is set correctly? Extending 20'' +-1/4'' or do I have to wait until the out drive is installed. I'd like to be able to check the trim limit switch now so I can replace it if necessary while the bellows are being replaced. I'm new to I/O as I've always had outboards. This is an A1G2 outdrive.
alldodge
You can run the trim but need the drive on because one side will extend/contract more then the other, so measuring will not be of any help
altitude 411
Copy that, thank you. I'll check limit switch w/ a multi meter then to at least make sure it is working...or maybe just replace them as long as I'm in there.
Ayuh,..... Without the drive on, the switch will never move,.....
altitude 411
HA ha. A yeah... Good point. I'm such an idiot. Like I said, never had a I/O but that one should have been obvious. Thanks
