Trim relay location
Gribster
Hi all,
I have a '97 FourWinns Horizon 220 with a Volvo Penta 5.7 and SX outdrive. While winterizing I was lowering the outdrive but forgot about the strap supporting it. The strap snapped (no big deal) but now the drive won't raise or lower. There is no sound at all when the control is pressed and I suspect that I've blown a fuse/breaker or the relays. I've checked all fuses under the helm and all are fine and I've checked the breaker on the side of the pump and it has not popped but I can't find any fuse related to the drive and I can't find the relays. Does anyone out there know where these are to be found on my boat or what the problem could be if it isn't fuse/breaker/relay related? Any thoughts would be appreciated.
Dave
QBhoy
Relays are usually near the pump. Sometimes on the aft bulkhead. Follow the wires from pump. If they aren’t attached to it even.
