I have just bought a nice trim guage that I would like to use on my Mercury 1150 from 1970. I have the powertrim system with the pump inside the boat and hoses going out to two cylinders. What kind of sender should I get and where to mount it?
Thans for your advice. Guess I will try to make my own solution, think a OMC sender that have a little arm might work. Just have to hope the resistans will match guage.
An OMC sender wont work on a mercury gauge. Different resistance. Off the top of my head I don't know the ohms requirements but OMC is different than mercury. In any case you MIGHT be able to rig up a linear potentiometer to run off the hydraulic actuators but waterproofing will be a hassle unless theres something close off the shelf.
If it were mine and I REALLY wanted a trim indicator I'd run a manual cable setup with a mechanical indicator ... such as half way down the page...
Of course the other choice is to mount a variable resistor next to the gauge. Adjusting the variable resistor will change the gauge setting. The gauge will look cool, and you can consider yourself as the trim sender. Just a joke.
