Trim sender problem.
shanz_2008
Hi every one.
I have a problem with one of the drive trim sender.
Wile the starboard engine is running the trim gauge goes up and down and sometimes stops in the middle.
Checked and clean the ground wire that is connected to the drive transom.
The trim senders are brand new.
I have bravo3 drive and 4.3Mpi engines 2007
Do i have to check somthing else?
Alumarine
Can you swap the sender wire from one gauge to the other to see if it's a gauge problem?
