1979 pre-alpha drive with trim sensors. starboard side of trim sensor has wires broken off right at the casing. under the little cover, I see two plastic pieces that the wires came out of, but no way to re-attach the wires.
Is this just an automatic replacement? do new trim sensors have wire that needs to be routed through the transom? or will new sensors have wire ends that can be hooked up to my existing sensor wires?
Can I put my outdrive back together and deal with this trim sender issue later without drive removal?
thanks
thanks
