Trim slow
birdy3897
Wondering if anyone has any suggestions to what causes my trim to go down slow but it goes up just great? I checked the fluid level and it is full. I guess I am asking what are the common remedies for slow trim? thanks
Re: Trim slow
It's High Pressure Hydraulics going Up,.......<br />And,....<br />Low Pressure Hydraulics going Down,................<br />It's got Gravity,+ Thrust both helping it Down......<br /><br />Have you Greased the Pivit Pins lately,...???.....
birdy3897
Re: Trim slow
I greased them and nothing has changed. It sounds like it is getting about half the juice going down than going up.
donwhiteside
Re: Trim slow
I'm a newbie, so this may be silly. But I was told that a rebuild of the internal seals may help this situation.
skiriver
Re: Trim slow
Need more info on what make system it is you are having a problem.
birdy3897
Re: Trim slow
1978+Imperial+120Hp <br /><br />It is a mercruiser outdrive.
skiriver
Re: Trim slow
Sorry, not familiar with Mercrusier. I'd suggest you check out eBay for a factory manual for your model. The manual will have a troubleshooting chart for your motor and outdrive. Hope this helps
