guyren
- Oct 10, 2007
- 26
My 87 90HP evinrude is missing the "trim" pin, the pin the motor bottoms out on when you trim down the motor. The motor has actually dented the side of the trim cylinder housing from coming down right onto it. No damage to the seals (yet) thank goodness.
Anyway, the last hole, lowest one, has a rust stain so there used to be a pin there but now it's missing. I guess it fell out.
My question is, can I just put a solid brass pin or a cold rolled steel pin in there. It's an odd ball size like 9/16" or 37/64" but I can probably turn down some standard size stock on a lathe. I haven't called the dealer for a new pin for fear it may cost a lot.
Your suggestion always appreciated
Guy
Guy
