Trim Switch / 1993 7.4L/Bravo 1
FuelishBehavior
I didn't want to hijack someone else's post but I have a similar problem to a recent post. My trim switch on the throttle will trim down but not up. However the trailer switch still brings the outdrive up. Is it my switch on the handle or is it the limit switch? A detailed test procedure would be greatly appreciated.
alldodge
That's your limit switch and the test is what you just did.
Edit:
You could pull the Blue/white and purple/white wires off the limit switch and connect together to bypass
