Trim switch replacement
dnpowers
Hey guys, looking for a replacement trim switch for a '78 85hp with one controls. Haven't been able to locate one. Any pointers?
Re: Trim switch replacement
Switch on the handle ?-----Is it a " powershift II " control box ?
dnpowers
Not sure if it is a power shift 2 or not. It is the trim switch in the handle
boobie
I looked on the evinrude site and they say NLA. Go to the top secret files at the beginning of this forum and look for salvage yards.
Jim19940
Hey guys---New guy on board, I am a Evinrude fan and owner. I need a wiring diagram that shows the wiring from the tilt switch to the tilt motor. I know about the 3 way switch, blue, green and red wire to the battery. There is a 3 way plug on the end of wiring harness---Green, Blue and black.----Should I ground the black to the battery and green and blue to the armature casing.-----I am told there is a white wire going to the armature fields from the points, is this wrong. If it is correct where does it hook to within the fields. Can you post a diagram..
Motor is a 1974 Evinrude 50 HP Sizzler, electric start.
boobie
It's not nice to hi-jack a thread. Please read the rules at the top of the forum and start your own. Thank You.
There should be lots of those used handles around.----Just a matter of looking in salvage yards, calling dealers etc.--Your location does have an influence on how readily they are available.
