trim switch replacement?
polevaults
How do I replace this trim tab switch on my 96 Mako 201?
gm280
Are you certain the actual switch is bad and not the wiring? If you've already verified the switch itself is the problem, then locate the control manufacturer and see how the entire assembly is built. Then order the correct part number and disassembly the control unit and replace... JMHO!
