Trim tab anode
slapeks
I need to replace a trim tab anode on alpha 1 gen II outdrive (gear1.94). Should I use the 31640 model with a fin or just a plate 76214?<br />Thanks.
Trent
Re: Trim tab anode
If you have power steering you can use the flat plate.
Re: Trim tab anode
And,<br />If you use the 1 with the fin,<br />Make Sure it Clears the Prop..........
