trim tab cavitation / usefullness
SeattleMatt
Hello, <br /><br />Since I have installed my 23P prop along with a smaller sized Zinc Tab now it seems that I am getting cavitation between 1500-2300rpm. It sounds like growling in the water.<br /><br />When I went to buy the new zinc tab, I asked for the one with no tab, but they said I wouldn't want that and talked me into a reduced sized tab instead. I am wondering what would happen if I were to just run a tabless zinc. There is some fear that the boat would steer differently.
crazy charlie
Re: trim tab cavitation / usefullness
Not necessarily.If the boat pulls a bit to one side as many do,the fin can be slightly angled to compensate.If your rig does not pull the tab w/o a fin wont make a difference.You will just get less zinc protection.Sounds like you may have the wrong prop on there or a spun hub.Charlie
If you have P/Steering,...... The Flat Plate will work Just Fine...........
SeattleMatt
Hmm, I have power steering, i guess i'll try removing it and see if it steers okay, if so then i'll take it back and get a flat one<br /><br />Thanks!
SeattleMatt
Well, I pulled it off and it still makes the growling sound between 1700 and 2200 RPM. steering pulls a little to the left, not much tho
